Looks like the IP was incorrect.
Type 192.168. 1.1 (the most common IP for Technicolor routers) in the address bar of your web browser to access the router's web-based user interface. You should see 2 text fields where you can enter a username and a password. The default username for your Technicolor router is admin.
Technicolor routers - Login IPs and default usernames ...
SOURCE: cant connect to another carrier internet with telstra technicolor TG797N V3
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
Hi Paul Matthews, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model cable modem? On your computer, that does the computer say the gateway address is in the network configuration?
Hi thanks for your offer of help, the Telstra modern had a complete meltdown this arvo and I purchased a new modem.
Thanks Paul
it is not useless,
only you fail know how to setup a modem router
step 1 is reset if ,owned by others, see NOT USELESS
a 30 second push and back to factory day one settings and was covered in you manual RTM?
no model told si can not read it to you.
his base address is
10.0.0.1 (or 10.0.0.100) depends no model number not told.
set by last owner the ISP or well gee any tech on earth.,
i never use defaults for IP ,that way any breaches puts them off my path, (a rule 1 security never make it easy for bad guys)?
and wlan no ping
and no WPS, nor PIN , no DMZ and well i have a long list.
the long push on the reset button does put it all back to day1, new settings.192,x.x.x
