The option button on the radio is not giving me options(nothing happens) when the button is pushed.
SOURCE: Buttons on TV or remote not working. Can only cycle through video input options.
It sounds as though the TVs in a demo mode. Has someone recently been over and was playing with the remote. If so go into the menu of the tV set and look for set up and demo mode. Turn off the demo mode. if this doesent help call i-866-427-3946 and talk to the customer service deptartment. Good Luck
SOURCE: control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
SOURCE: Blue buttons (quickplay/sound/dvd controls) won't work
Mine did that as well then after rebooting started working??
SOURCE: ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
SOURCE: my nokia c3 radio doesnot
good day
coul you please advice me on how to access nokia c3 radio i press select but nothing happens whta sahoul i do
