Question about Refrigerators
My ice maker is coated with ice. Can i defrost it somehow?
    Top Expert:
  • Refrigerators Master
  • 6,289 Answers
You can but that won't stop if from doing it again. Most likely ice maker is defective allowing water valve to stay open too long
Posted on Nov 12, 2017
    Habit-Forming:
  • 184 Answers
Yes, try a heir dryer.
Anonymous
SOURCE:
Anonymous
  • 750 Answers
SOURCE: ice maker
Hi chjnt,
What is the model and age of the fridge?
If it is a side by side and you did all that for it already, perhaps it may need a replacement ice maker.
They are not complected to install!
Thanks for giving me the opportunity to help!
Let me know any other info you may have.
I think it needs a ice maker replacement!
Please do not forget to give a rating before you sign off!
Thank You, HUUUM
Here is and interesting report!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Posted on Sep 21, 2008
Anonymous
  • 700 Answers
SOURCE: How do I get water line to ice maker defrosted?
you will have to remove the Ice maker and the use either a hair drier or shop vac the blow air onto the line unit it thaws. Have a Merry Christmas and thanks for using FixYa.
Posted on Dec 25, 2008
SOURCE: ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
Posted on Apr 14, 2010
Anonymous
  • 77 Answers
SOURCE: ice maker was frozen & we used a hair dryer to defrost and now it
If there were ice cubes in the ice machine and it was doing nothing, then the ice maker is bad and you will need a replacement. This happens unfortunately. It is nothing that you did with the hair dryer tho. If I have misunderstood the problem I will gladly help further pending more information :) gl!
Posted on May 29, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: ice maker has stopped working and auto defrost doe...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
kjffkjk
Posted on Sep 30, 2010
My LG lsc27910tt ice maker arm is stuck in the up position and won't budge.
there is a good chance that some ice has jammed in there somehow. have you tried defrosting the machine... that would be the first thing to try.
Oct 11, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
KITCHENAID ICE MAKER STOPPED WORKING LED BLINKS WHEN FREEZER DOOR IS OPEN
Try firs unplugging power for 510 minutes, see if it reset.
Oct 10, 2008 | KitchenAid Refrigerators
We accidentally left the freezer door just barely open overnight. The freezer started to thaw somewhat, but we caught the problem before anything had to be thrown out. In other words, there wasn't a lot...
yes ice formed in the bottom of the ice bin locking the auger from turning to dispense ice. Defrost the ice bin and wipe clear of any left over water from the melt.
Appliance 911 Sea Breeze
Mar 14, 2017 | Whirlpool Refrigerators
Freezer won't reached desired temp or make ice
Most definately you do. somehow air got in while you were away. 12 hour defrost with doors open will help.(insulation in side by side normally thick).Had one like that approx. 2 months ago but fridge was not well treated and they damaged rubber seal at water and ice dispencer area.
Jun 06, 2010 | Bosch B20CS51SNI Stainless Steel Side by...
Whirlpool side by side refrigerator out of order
Normally I would say you should check the defrost circuit, and maybe you still should, but I am more inclined to believe that your ice maker fill hose has either popped loose from it's fitting or that it has a gash or gouge in between the back wall of the freezer and the cover plate for the freezer coils. This will mimic the same symptoms you get from a bad defrost heater, defrost thermostat or defrost timer.
If this is true, the quickest way to verify a damaged hose is to remove the ice maker and all collection buckets as well as any freezer mounted plastics that stand in the way and find that ice maker fill tube.
When you find it inspect it for clogs and obstructions.
Then try clearing it even if you dont see one with a coat hanger.
Mar 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker leaks water into holding container, frezzes up holdeing container, ice wont despence , because its froze
sounds like your ice maker has a degraded coating on the mold that forms the cubes. if you remove it from the freezer, then you can see if the coating is coming off. if so then you need to replace the ice maker.
Jan 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Fridge and Freezer quit working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer stopped working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Mar 22, 2009 | Kenmore 57029 Side by Side Refrigerator
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
No water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Jun 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Refrigerators Logo
    47 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
