I have the four screws out, but the two alignment pins are stuck OR there is something else holding it together. All I need to do is repair the power lead just inside the case!
Make sure there are no more screws to take out then carefully pry apart, gently.
Testimonial: "Wayne, thanks. I failed to close out my question after the problem was resolved and I apologize. The motor case was extremely tight! The method that worked was to use several utility knife blades as splitting wedges. They are hard steel and brittle, so WEAR eye protection! It took a long time, the small brass hammer I was using did not work but I held it firm then used a big ball peen to smack the brass... etc. The pins are so tight they might be called an interference fit. Then it was on to pulling the bearings and that was another long adventure. Although there was nothing gentle about it, there was no damage at all, even cosmetic... Thanks again and Happy New Year to you. mike"
SOURCE: Cannot find specs for my DeWalt Radial Arm saw
Here you go.hope this is what you wanted and Please rate this a fixya
SOURCE: Craftsman Radial Arm saw.
Have you already tried Sears Parts Direct?
Available by clicking here, you'll need to have the model number handy.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
SOURCE: trying to get the manual for the DeWalt 7730
go to Dewaltservicenet.com and in the middle of the page type in your model number and you can download a manual for this tool. It is 27 pages long, If I have answered your request would you please rate this response accordingly and thank you..
Testimonial: "yes - this was very helpful - thank you very much. This is a great system. "
SOURCE: where to get a dewalt radial arm saw manual for a 125
Yes I have the original "adjustment and operating instructions" and "Manual of spare parts,wiring diagram and accessories" give me yoru email and I can scan them for you. On You tube you also find good info.
Sten
