I always look for the simplest answer first.
This MAY be the problem: you reinserted one or more of the batteries with the wrong orientation. Typically, they will connect in series to produce a higher voltage than a single battery by itself.
For example, an AA battery puts out about 1.5 Volts, and two AA's in series would produce about 3 Volts, with the positive of one battery connecting to the negative end of the other; the negative of the first and the positive of the second connect to the remote's terminals. The connection between the two batteries is usually in the battery holder in the remote, and the batteries will be physically oriented in opposite directions. For example:
Of course, something inside the remote may have broken instead, but double-check the battery connections first.
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
SOURCE: Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
SOURCE: my hunter fan is not working. the remote has a
It sounds that fan use to work and lights and you did correct thing by changing battery. I've had this problem and it just needs the reciever replaced. Reciever is located at electrical connection in ceiling. Just buy a new universal wireless remote and reciever at any home depot. if dont fill safe doing this task should call an electician to do job or someone with electrical skills.
