SOURCE: Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
SOURCE: Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
SOURCE: Soap dispenser stuck on LG WM2277HW
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
SOURCE: soap dispenser does not close
Make sure the dial is at the start positon and not in between on some other setting.
SOURCE: The soap does not fully 'dissolve' after running the unit
I believe this is just a matter of dish placement, and not a matter of anything physically wrong with your unit. The way the unit works is when the "computer" tells to open the door, it releases the latch. That is all it is responsible for doing. After that gravity and the splash of the water jets must take over. So simply just make a visual path where you know water jets can hit that area and you should be alright. IF the powered soap is already caked in the dispenser you will have to manually scrape it out with a wood or plastic stick.
