Music Logo
J
John Coffey Posted on Nov 16, 2017
How to send LR outputs to aux mackie dl806 - Mackie Music
Lubomir Beer
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Nov 18, 2017
Lubomir Beer
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
250
Points
15
You need 3.5 mm Stereo Jack to 2 RCA cable.
  • Lubomir Beer
    Lubomir Beer Nov 18, 2017
    Sorry, Stereo 3.5 mm Jack to 2 x Male XLR Cable
1 Related Answer
Fred Yearian
  • 5603 Answers
  • Posted on Aug 11, 2010
SOURCE: intermittant LR output problems Main outputs (XLR
Intermittent problems cn be a real pain to find... BUT I want you to verify your use of the mixer and its connections as one can cause the output drivers to latch up due to ground bounce.
Make sure your outputs go to the power amps AND into balanced inout at the amps... either XLR or TRS connectors.
Make sure that the amps are POWERED from the same receptacle as the mixer... even if you have to run power back to the mixer. If you power the mixer from a different receptacle at the other end of the room, ground bounce of the safety ground MAY exceed the common mode drive of the mixer and cause the output drivers to latch up or even be destroyed!!!
Mixer signals is on but qsc 1450 amp not giving any sound when main output is connected but when run aux send to amp it gives sound. What might be the problem.
If you are experiencing an issue where the QSC RMX 1450 amplifier is not giving any sound when connected to the main output of your Mackie 16 OK mixer, but works when connected to the aux send, here are some possible causes and solutions:
  1. Check the main output level on the Mackie mixer. If the level is too low or muted, this can cause the amplifier to not produce any sound. Increase the main output level on the mixer and check if the amplifier produces sound.
  2. Check the cables connecting the mixer to the amplifier. If the cables are damaged or not connected properly, this can cause the amplifier to not produce any sound. Ensure that the cables are connected securely and are not damaged or broken.
  3. Check the amplifier settings. Ensure that the amplifier is set to the correct input source and that the input gain level is set correctly. You may also want to check if there are any protection modes or limiters enabled on the amplifier.
  4. Check the speaker connections. If the speakers are not connected properly or are damaged, this can cause the amplifier to not produce any sound. Ensure that the speakers are connected correctly and are not damaged.
  5. If none of the above steps work, there may be an issue with the mixer or the amplifier. You may need to contact a qualified technician to further diagnose and repair the problem.
Remember to always follow the manufacturer's instructions and safety guidelines when working with audio equipmen
How do I hook up my Alesis Microverb III effect to Mackie CR1604VLZ and allow maximum aux sends for monitors ?
What you need to do is connect (for example" Aux 1 send from the desk to the Left Input of the alesis. Then connect the Left and right output form the Alesis to Auxilery return 1 and 2. You can just use the left ouput and use aux return 1 if having mono effects is ok.
How do i hook up monitors to mackie1604 vlz pro to where you can hear music and mike.
Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
Why does my mackie cfx12 mkii have low output across all 8 xlr inputs at unity gain with distortion above that?
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Aux Channel 1 not working
What makes you say it works fine if you are getting no output? Have you just got it turned down?
I am trying to run a monitor using the Aux Send on a Mackie Board but even with the Master Aux Send turned up there is barely any sound coming out when I try to use my microphones. Also, I noticed that...
No there is no special cord. The aux you use for a monitor should be pre fader( that means the signal comes before the volume slider) turn the individual slider all the way down. Talk into the mike at the volume you would be singing at the loudest. Adjust the gain of that chanel up untill the clip light comes on. Now back it down so it dosent come on at your loudest. Now pick the aux you want to use. Turn it up 1/2 way, turn up the master aux send coresponding to the channel aux number 1/2 way you should get sound. If it's too loud turn it down if you need more turn it up. If you have any more questions, give me a call at the shop.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
[email protected]
[email protected]
www.prolinemusic.com
1helpful
How to connect effects processor to mackie 1602 mixer
Should be an Aux 1 or 2 output jack on the right side of the mixer. You can come out of the 1 or 2 OUTPUT jack to the input on your processor, and then from the output of the processor to Effects return or to a channel input. By going to a channel input you can then blend the processor's signal with a slider into the sound system with the other channels, while adding tone if needed. By going back into the Effects return, you just blend it overall by adjusting the Effects return knob.
To feed the channels through the processor, turn the AUX 1 or 2 knob up on each individual channel you want to go through the processor. Make sure the AUX 1 (or 2 if you are using that) MASTER knob is turned up on the right side of the console, otherwise nothing will go to the processor. You should see the processors' input light showing signal, if not check your connections. Good luck
What r the 5 output possibilities for the mackie 1604
On page 28 of your user manual there is a block diagram. You will find the outputs on the right side of the drawing... They will innclude the mains, the mono, the subs and aux andd the tape outputs. There are a bunch and many are stereo types.
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
My 1604 VLZ Main Out bus keeps failing all the time, dramatically reducing the output level and also producing some noise artifacts. I usually have to put the levels to maximum course and it returns to...
is level pot defectives, needs to be replaced, u can change-them but is very comfusing, needs the same pot ref. u can find on electronics store, but probably dont find them easy, better send to repair. time spend to find them is long.
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
