SOURCE: THE FAULT CODE IS F9 ON A FAGOR DISHWASHER
Problem with distributor motor (or alternative motor). Motor locked, or sensor not detecting its rotation
SOURCE: .85/lb of nuts and .55/lb of nuts to equal 60lb @.75/lb
Convert what you know into a couple of equations. You'll need two equations because there are two unknowns. Call them X = pounds of nuts that sell for .85/lb and Y = pounds of nuts selling for .55/lb.
Equation a): X+Y=60 (total weight sold is 60 lbs)
Equation b): .85X+.55Y=45.00 (because we want to sell 60 lbs at .75/lb)
Rearrange a) to X=60-Y (subtract Y from both sides)
Plug this into equation b) and solve it for Y:
.85X+.55Y=45.00
.85(60-Y)+.55Y=45.00
51.00 - .85Y + .55Y = 45.00
51.00 - .30Y = 45.00
6.00 = .30Y
Y = 6.00/.30 = 20 lbs
From equation a) then, X = 40 lbs. Check the results by solving equation b).
.85x40 + .55x20 = 34.00 + 11.00 = 45.00 (checks!)
(If either of those nuts is pistachios, where do I send my money? That's a good price and I want some!)
SOURCE: fagor, washer dryer , model 2F-3611 flashing
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
