AS it is the vibration of the golf cart will not allow heater to stay lit, the heater will not tip over.
Don’t, the device is there to prevent fires.
SOURCE: To much flame with my Mr Heater. What do I do?
reduce the air to burn on the burner you should be able to do this where the burner fits on to the injector
SOURCE: Is it o k to bend the thermocouple tip. The only
Bending it will ruin it. You need to find out why the pilot flame is not as strong as it should be.
It is usually caused by bugs or spiders having gotten into the small air mix jet of the pilot assembly and died or built a web or, there is some dirt from the fuel that is partially clogging the fuel tube leading up to the pilot assembly, or plugging the orifice.
Testimonial: "worked perfectly"
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Adapter is ng/get one that works. Or the adapter connection may not be good. Check for voltage output at that connector.
