SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
SOURCE: trying to hook up an
If you want to hear the sound from all the sources (including the Playstation) thru it you will need to connect all of them to the receiver and the sound bar to the Line-Out or headphones socket of the receiver.
You will need a cable that has an 3.5mm jack at one end (for the soundbar) and 2 RCA connector at the other end (if you use the Line-Out connectors) or another 3.5mm jack and an adaptor to the large one if that's what it has (if you use the headphone socket).
SOURCE: how to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
SOURCE: How to hook up a sound bar to a Apex 32in tv # Ld 3288 t
Please follow guidelines in operation manuals of both.
SOURCE: I am trying to connect a lg sound bar to a
If you have a digital coax out, or vice versa, they make digital optical convertors. Try MCM Electronics.
