Hi Rick.
this is all i could find not sure if it will help you out but have a look and a read up might help you.
Printer Not Recognising Compatible Cartridge 8 Steps To Take
you could also try this link out.
LD016 WON RECOGNIZE NEW TONER CARTRIDGE Google Search
SOURCE: Toner cartridge end of life message
Just unscrew the side of the toner and reste the metalic plastic tab (silver ..) and that's it
SOURCE: Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
SOURCE: Ricoh 2045 Doesn't recognize new toner cartridge
This is probably one of two things, first it could be is that the stopper out of the old bottle has got stuck inside the Toner hopper and preventing the hopper from getting toner from the new bottle.
This would be caused by the second problem that is the hopper is more than likely clogged up and the jaws that grab the toner bottle cap cannot open, you can either clean the hopper out, it can be dismantled by removing the silver pin on the green handle, but do be care full as when this pin is removed you will fire the internals out accross the room, so have your hand in front to cach them, then just clean it out reassemble and you should be fine.
Just remember always try the simple fix with copiers, so many engineers look way to far into problems whenit's staring them in the face, i am a Technical Specialist with Ricoh Masters and find a lot of basic faults are overlooked
SOURCE: Put in a brand new
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
SOURCE: canon printer won't recognize new ink cartridge
did you take the shipping tape off of the cartridge? It's usually the one covering the contacts located on the underside of the Cartridge that is inserted into the receiver of the cartridge. Other wise, you may have a bad cartridge, if so, bring it back to where you purchased it and get another one. Chris [email protected]
