This noise most likely caused,not by the belt,but 1 or more of the moving drum support wheels and or the pulley that snugs the belt around the tumbler. nominal difficulty to repair. Complete kit available on line.$50 or so. Going to need your MODel # when ordering. Hope this helps.
Happy Holidays
SOURCE: how to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Testimonial: "Thanks for the info!"
SOURCE: how do you replace the drive belt on the whirlpool DUET
The following link explains step-by-step how to replace the drive belt on a Whirlpool Duet washer:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
This is a very simple procedure, but if you experience any difficulties, please post back and let me know. I hope this helps you.
SOURCE: 04 forester turbo alternator belt squeals a little on startup.
the auto belt tensioner should do it by itself if not may be your belt has stretched so you may need a new one
SOURCE: GE/Whirlpool Duet electric dryer squeals badly...
A
common problem with noises from washing machines and dryers has been the under
wire that may come out of a bra. In the washer they can get stuck in one of the
inner basket holes and make a scrapping noise, they can actually make there way
into the pump and jam the pump, or make a terrible noise when the pump is
running. Grab a flash light and have a peek inside the washer for this. Front
load washers seem very common to this happen! In dryers, they can get caught in
one of the drum seals and make a scrapping noise, (remove power, grab a flash
light and have a peek inside through the door opening) or the wire can actually
pass through one of the heating duct holes at the back of the drum and touch
something electrical like the heating element, thermostats. If your
washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing
machine doesn't spin. The switch is inside the washing machine main housing
near the door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to replace
it.
The motor coupler may be broken. Many
Whirlpool®-manufactured washers use a small, relatively inexpensive motor
coupling. It's plastic and rubber and is mounted to the shaft of the motor on
one side, and to the transmission on the other. Over time, the coupler wears
out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or
two belts. If a belt is broken or badly worn, you need to replace it with a
genuine belt from the manufacturer. (Some washing machine belts are designed
with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use
a clutch to come up to the proper spin speed. As the clutch wears out, it may
prevent the unit from spinning well or at all. If the clutch is worn, you need
to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
The drive motor may be defective. Many washer brands use a
reversing motor. For agitation the motor runs in one direction, for spinning
and draining, the other. It's possible for a motor to burn out in one direction
and continue to operate in the other. If this happens, you need to replace the
entire motor.
The transmission may not be shifting properly. Older
washers produced by Whirlpool® have a transmission with an electro-mechanical
shifter. If the shifter becomes even partially defective, the unit may drain
the water but not spin. This is a complex system, if your washer has a shifter
problem, you may want to hire a qualified appliance repair technician to repair
it.
The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When
this is the problem, you usually hear a loud sound during the spin cycle. Call
a qualified appliance repair technician.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
Hi Terry Parker, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? model number
WED 9200 SQO
