Question about Samsung Washing Machines
I have a samsung washer dryer combo model WD8603R8U i need a pump for it. and a manuel
    Top Expert:
  • Samsung Master
  • 54,386 Answers
Fixya does not sell replacement pumps. As for the manual, try Googling (Samsung)(WD8603R8U)(manual) without parens.
Posted on Nov 24, 2017
6ya staff
SOURCE:
Lumpy816
Toby Norton
  • 246 Answers
SOURCE: Frigidaire washer/dryer combo
For that model you should just be going through the front. There are 2 phillips screws at the bottom of the front panel. After you remove those, you will need to slide the front panel down. (sometimes insreting a large flat head screw driver between the top washer panel and the front washer panel will help ease it off). The pump on this one is one of the easier one's to clean. Use a shop vacume or just bail the water out by hand to remove as much as possible. Follow the large black hose running down from your tub to the white plastic looking peice. That is your pump. The are 2 5/16 screws holding it down. Remove these to make your work easier and cleaner. Also remove the connector/ wires that plug into the side of the pump. Once removed raise your pump up and slide a large, flat container underneath. Squeeze the clamp on the hose and slide it further back up the hose. Now, SLOWLY start working the hose off in a rocking motion. Just a little pressure here. Now as it strats to work off, the rest of the water will start to come out. Drain it a little at a time. Work the hose back on if you have to go empty your container. Once all of the water has been removed, pull the hose the rest of the way off. Do you see anything blocking it? No? Remove the hose coming back out of the pump as well. Still nothing? Try removing the hose that goes between the tub and the pump up by the tub this time. Nothing yet? Try plugging the pump back in and setting it to a spin/ drain cycle. (make sure you are not on the part of the cycle that adds water or there will be a mess) Once you are on the spin/ drain cycle, look into the pump. Is the paddle wheel looking piece inside moving? If it is not, and there are no forign objects in there, it may be time to replace the pump itself.
Posted on Jun 25, 2008
Anonymous
SOURCE: Supra Wash/dryer combo Model SW5l30D
check the heating element for power.
Posted on May 03, 2009
Anonymous
  • 62 Answers
SOURCE: need manuel for maytag stacked washer/dryer unit model lsg7806aae
go to this link and download the manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LSE7806A&siteCd=MT_EN_US
Posted on Sep 02, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Posted on Sep 29, 2009
Anonymous
SOURCE: Need Manual for Frigidaire Gallery Heavy Duty Washer/Dryer Combo Model #FLSG72GCS0
my washer make a loud sound when spinning
Posted on Feb 11, 2010
I need a water pump for a Kariba WD 802 washer/dryer combo.
Joan, just enter the name and model of your machine into a web browser, i.e. google, bing, yahoo et al, and the words spare parts, spares, or the like along with your state, / county / city / town and hit the search button, this should throw up plenty of results that you can trawl throygh and select your preferred supplier.
Jun 08, 2016 | Splendide RV Combo Washer Dryer - Vented
Looking for a haier hd1500 waher& dryer combine manuel
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 23, 2011 | Haier 14.3 lb. Washer/Dryer Combo
Where is the lint filter?
Is this a front-loader? Samsung hides the filter behind the lower panel on the front.
You can view your machine's user manual here (you need your model number):
http://www.samsung.com/me/support/productsupport/download/index.aspx
Apr 30, 2010 | Samsung Washing Machines
I am looking for a manuel for Kariba washer/dryer combo
Hi, Can you provide the model number, i.e. WD1043. It should be right on the front panel. I have some lierature but not much, so let me know and I'll watch for your reply. Macmarkus :)
Mar 24, 2010 | Washing Machines
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Kariba washer/dryer
I HAVE A (KARIBA) WASHER AND DRYER COMBO,, MODEL# WD802 , AND LOST THE MANUEL TO IT. CAN SOMEBODY FIND ME ONE
Dec 23, 2008 | Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
