Light above button does come on. all other parts of this two group machine functioning. all wiring appears intact.
SOURCE: Please help remove the on screen display of channel number
I hit the TV button on my COX cable box remote. I prayed about it and started doing what my wife said she had done. She had hit all of the buttons on the remote. I did the same thing.
When I hit the counter-clockwise circle with the arrow head on it the channel number on the screen went off.
Praise the Lord! Thank You, Jesus!
I had been trying for about a week to get the channel number off of the screen to no avail.
SOURCE: the record mode does not function on the right side.It does play on both sides!
Place the speed on X1 mode to make sure it is off the B mode and it should record.
SOURCE: No Coffee dispenses
That is exactly what I would've suggested, the brew unit is clogged. remove brew unit and try to blow through the top, if you get through then check the bottom. One of the chambers must be clogged. Another question is the coffee extract wet or dry grounds?
If wet then the block is on the top, if dry it ids on the bottom.
SOURCE: The button on the front has functions but when I
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu
button on the front panel for 10 seconds. If the OSD is locked, the
warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
SOURCE: I've got a faema E91/A 3 group espresso machine.
the original cord how many wire have? on the label what writes? if you have 5 wire (blue= null or neutral, green whit yelo= grounding, brown, black and grey= phases, is posible to have a red wire instead of grey, black or brown wire), on the blue wire whit one of the phases must have 220 V, on the brown whit another phase you must have 380V, if you had a bad conection is posible to damage something in electronic automatisation of the espresso machine, that machine must be conected in a water suply whitin a softner an befor use is posible to must be triggered manually. by the way, this machine must be proper instaled by a specilised personell beacause it is the risc of electric injuri and other bad things. your E1 is posible to be a temperature probe damaged or because of water mising and in 20-30 min. the machine was reaced a high temperature and safety thermostat has occurred. the best you can do is to call a repairman to solve this, if you try to repair your self it is posible to make worst.
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
