There are 5 speakers and a sub. 4 speakers worked initially but then nothing with SD. Unsure if I have accidentally pressed something, but have tried everything I can think of. This is a brand new Humax purchased today. Thank you Claire
SOURCE: HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
SOURCE: No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
SOURCE: no sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
SOURCE: trying to get surround sound speakers to work with TV
They come with 3 x 3.5mm stereo to 2 x RCA phono cables, so are obviously meant for plugging in to the back of a PC with 6ch output.
BTW - they're ****.
I should've known for £29....
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
