Navman f100t when on and off, hve start up screen showing but froze cant do nothing else and when you slide to reset all goes off when back on im back to start ,, nothing it manual about resetting my last navman had o hole you pult a point in , and job done thi s just has a slide ON/OFF/RESET.
Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
Plug the unit into its charger using the USB port on the
bottom of the unit. The battery indicator light next to the power switch
should turn orange, indicating that the device is charging. Once the
light has turned green the charge is complete. If the light does not
turn on, verify that the car charger is plugged into a working outlet.
The only other option is to dis-connect B+ power to the GPS system for 60 seconds in hopes it will reset the processor, before you hook the power back up press and hold the reset button for at least 60 seconds to bleed off any residual charge, If all this fails you should consider a replacement unit.
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
GO TO PREFERENCES ,LOCALIZE , LANGUAGE, UK OR US ENGLISH . EXIT BACK TO LANGUAGE , TAP VOICE , MALE / FEMALE TAP TICK . ALSO INCREASE VOLUME ON SIDE OF NAVMAN + OR -
