Hi there.
this is all the info i can find on this.
Key Features
What is the capacity of front loading whirlpool washer MO GHW9150PWO...
SOURCE: Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
SOURCE: Whirlpool Ultimate Care II LSQ9564J Top Load
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
SOURCE: I have whirlpool washer model ghw9150pwo. Control
Press and hold the end of cycle button fo 3 seconds
http://appliancehelponline.com/frontloadlocked.html
SOURCE: WHat is the capacity of
Hello there
is one of the better, super-sized porcelain-on-steel wash basket,
combined with the Xtra roll action plus agitator, which ensures that
your really big loads get really clean! The dual action of the Xtra Roll
Action Plus agitator rolls even huge loads to the bottom of the wash
basket where cleaning takes place. It can effectively roll over and
clean twice the average size load! Plus, wash fewer loads to save time,
money and energy! Ultimate Care washers offer both five and six speed
combinations providing flexibility for the future in fabric care. Plus,
the easy-to- use consoles makes it simple to select the desired
wash/spin speed combination. And the enhanced agitator vanes ensure
clothes roll over for consistent cleaning -
