Tablets & eReaders Logo
J
John Gordon Craig Posted on Nov 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to remove Outbox & JunkEmail from my IPad,can you help please?
NOEL
Level 3:
Top Expert:
  • Tablets & eR... Master 8,606 Answers
  • Posted on Nov 25, 2017
NOEL
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2320102
Points
68630
Hi John.
How do I delete my junk mail on my iPad? Tap the Edit button at the top and press Delete All. To save you the bother of doing it again go to Settings on the home screen, select Mail Contacts Calendars then your account and touch the Advanced button. Under Deleted Messages select Remove and choose an appropriate timeframe for automatic deletion (i.e.13 Aug 2012
How do I delete my iPad emails? - Telegraph - The Telegraph
www.telegraph.co.uk/technology/advice/.../How-do-I-delete-my-iPad-emails.html Search for: How do I delete my junk mail on my iPad?
To mark a message as junk:
  1. On your iPhone, iPad, or iPod touch with iOS 7 or later, open the message, tap the Flag at the bottom, then tap Move to Junk.
  2. On your Mac, select the message and click the Junk button in the Mail toolbar. ...
  3. At iCloud.com, select the message, then click the Flag button and choose Move to Junk.
Identify and filter junk mail in iCloud - Apple Support
how to remove Junk Email from my IPad Google Search
I need to get rid of my passcode on my ipad 9.7 pro and my iphone 7plus i need help asap thank you
You can remove passcode from iPad by restoring your device with iTunes.
Step 1. If you've matched up your iPad with iTunes, you can reestablish your device.
Step 2. Associate your gadget to the PC you matched up with.
Step 3. Open iTunes. On the off chance that requested a password, attempt another PC you've synchronized with, or utilize recuperation mode.
Sit tight for iTunes to match up your iPad and make reinforcement.
Once the synchronization and reinforcement have finished, click Restore. After clicking Restore, you have successfully remove iPad passcode with iTunes.
How to Remove Passcode from iPhone
Cannot open ipad asking for a pass code and says ipad has not been updated
You can try the default password or just remove the password. Follow below steps to do that.
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number.
If this won't work, try below method.
When you find "iPad asking for passcode I never set", it is sensible for you to remove iPad passcode by restoring iPad with iTunes. The precondition is that you have backed up your iPad to iTunes before you forgot the passcode. Now let's begin to see how to get this work done.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more details, check: Fixed: iPad Asking for Passcode I Never Set
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
My server had a problem with e-mails and now I have a lot of e-mails sitting in my outbox with a red exclamation mark on them. Now, do I need to resend those by forwarding them or what?
You have to open each one separately and resend it. If you continue to have problems, check your password, or your outgoing email settings.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
How do I delete a blocking sent email on my ipad?
This is one way I've found to delete an email stuck in the outbox (which is what it "sounds like" you are asking...)
1. change ya smtp settings so the message defo wont send!
2. send a test email to anyone
3. it will attempt to send but oversiously fail...
4. hopefully the outbox should be listed with 1 message waiting to go out...
5. if not, try going into the Activity Window and canceling the send command, that should show it up...
6. click the Outbox and the will be one message listed...
7. goto View -> then Show Favourites Bar
8. you should see a favourites bar appear...
9. simply drop and drag the Outbox into your favourites bar...
10. if you restart ur laptop or close mail and then the Outbox has disappeard, simply click the Outbox in you favourites tab and woop woop it should appear in the Side Bar
I done an update for my iPad today .And by accident.I filled out a passcode .So every minute I use my iPad .I have to keep typing my passcode .It is no good for me .I need to remove please .
Hi! Go into your settings click in pass codes then it will tell you to type in your password then you can follow the prompts so very easy I hope I helped you! Stacy Evers :)
At the start , forgot 4 digit pass word,for ipadmini
There are several solutions to solve your problems. First you can try the default passcode 1234. But if you surely forgot 4 digit password, you have to restore the password. And below steps can help you.
For more methods, check: Remove iPad Passcode through Restoring iPad with iTunes
How to reset your restriction code
The only way to reset your restriction code is if you know the existing code. Since it appears you do not know the existing code you will need to restore your iPad to remove the code.
Simply, connect your iPad to your computer and open iTunes. Perform a backup so you can later re-add all your apps. Then perform a restore. This should remove the restriction code.
Hope that helps!
Aloha! i just got a new ipad and would like to
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
