SOURCE: Can't get cable channels, only goes up to ch. 13
First check and see if you are on Cable or Ant. It sounds like you are on ant. Change it to cable. If you are on cable then it's you tuner, you need to replace it.
SOURCE: 13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
SOURCE: Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
SOURCE: New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
SOURCE: I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
