SOURCE: Ice Maker too slow
bayfishr, I'll try to give you an idea on how this thing works and let you do some checks. The cycle is controlled by temp. The harvesting process begins when the IM thermostat closes signaling the harvest temp has been reached. The closed thermostat supplies power to the IM motor and heater. Therefore the colder you keep it, the faster the production unless something has failed. I see a lot of heaters fail. You can test this. When the IM starts it cycle, test the voltage from L to H on the module,they will be marked. Should read 120V. The heater on the bottom of the mold should be getting hot. Disconnect the harnes and ohm it. Should ohm out at approx 72 ohms, same test points. If this checks good, check the center wheel on the module itself. Two clips keep the wheel in place. If one is cracked off, the IM will not fucntion properly. Other than colder temps, there is no way to adjust the speed of the cycle. Keep the flap in front of the ice-maker down so that the cold air is drawn across that IM. Catriver.
SOURCE: ice maker not making ice
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
SOURCE: ice maker not making ice fast enough
Hi!!! Also make sure that your freezer section is bet'w 5 to 10 degrees if not then you have a frig problem..If you have 10 degrees or so then you have an icemaker thermostat control problem.You have to buy another icemaker unless you can replace the icemaker thermostat inside of it..Good luck..
SOURCE: The flap on the ice despenser is not closing and
If you can look up and see the flap is loose or sloppy, you need one of these two kits. Kit # 8201649 is the chute door, door bracket, spring, damper pot.
Kit # 8201756 contains all the above plus a metal bracket designed to replace the housing bracket, the door pivot pin and a metal brace.
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
