Also checked trigger handle everything there was in proper order
SOURCE: poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
SOURCE: hesitation during acceleration
could be the type of plug you are using.I was told only to use ngk plugs.I recently put bosch plugs in my mazda 3 and the check engine light came on and it started missfiring.
SOURCE: Gilera Nordwest Carb setting
I have a gilera RC 600 which has the same engine as the nordwest, the problem could be the carb needs to be stripped and cleaned and replace the foam air filter with a paper one. For accurate advice and spares which are quickly posted, contact BOB WRIGHT at 0044193451033. He is the official UK gilera specialist, tell him I sent you, say the guy in southern Ireland, and he will look after you. Good Luck.
PS please rate me if this helped
SOURCE: 1994 Yamaha Waverunner 3 will idle but wont take throttle
Switch to reserve tanke to check to see if there is a clog at the fuel pickup in the tank.
My friend had the same issue with his waverunner 3.
