If you are using the supplied Acer program to setup your wireless, I would suggest removing the program. In most cases, removing their software does not remove the drivers, and thus, Windows Zero Configuration will take over the wireless.
WZC, in my opinion, works very reliably and has solved this type of issue in the past, although it is not the only reason for disconnects. For instance; a weak signal and a lot of interference from neighboring networks can cause your wireless to become unstable.
If this doesn't fix your connection issue, you may have an issue with the wireless card itself.
Testimonial: "Thanks, but how do I turn off the Acer software?"
Why do you have 2 different routers? Are they both broadcasting? How many Internet Service connections do you have?
