SOURCE: Refridgerator and freezer is no longer cold
evaporator freezer fan motor has low voltage. Amana M # SCD22NW S # 9403120669. Could use some help. Thanks
SOURCE: freezer is not freezing and refridgerator is not cold enough
have the freon checked for leaks, also check to make sure the compressor is coming on. If it comes on and is warm, boost freon. If the unit is not coming on properly, check the capasitors and compressor
SOURCE: top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
SOURCE: freezer is cold refridgerator is warm
PURCHASE troubleshooting refrigerators at https://www.applianceuniversity.com/store/products/Secrets-of-T%7B47%7DS-Refrigerators-%231009.html
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
