SOURCE: UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
SOURCE: Windows XP screen is flipped upside down...virus?!
Virus is possible but check the software for your video driver first. This has keyboard sequences that allow the screen to be rotated. Minimize any windows you have open till you have the desktop on the screen. Then on a blank area of the desktop in the middle of the screen right click mouse. If you see an option for screen properties or rotate screen or screen options choose it. In there you should see an option for rotating the screen
SOURCE: upside down and flipped numbers
Press [CLEAR] to erase the screen. If that does not work reset the RAM
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then press [CLEAR].
If these steps fail, you should read the article.
Hope it helps.
SOURCE: The lcd is flipped upside down how do i repair and
Hi
The problem you are experiencing has to do with the flex of your phone.All you need to do is to open your phone with a phone screwdriver and check the flex if it has not shifted from the right position then you would adjust it properly.
If it doen't work properly after that then you would need to replace the flex of your phone.
GOODLUCK
Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down.
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW
please issue positive feedback for me
