1997 Mercedes-Benz E-Class Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Overheats, and wont switch gears at times.
I have a 1997 mercedes e class that overheats, and wont switch gears at times. I thought it was b/c it needed an oil change, but still has this problem afterwards too. My car will get me to a place but then it takes an hour or so before my car starts up again when i am ready to go again. It won't turn back on for an hour after i last turn my car off.
Jason Johnson
Level 3:
President:
  • Mercedes-Benz Master 1,619 Answers
  • Posted on Aug 17, 2009
Jason Johnson
Level 3:
President:
Answers
1619
Questions
0
Helped
440985
Points
3913
Well overheating and not starting are possibly 2 different issues. Oil is not the cause of overheating. Thermostat, water pump, electric fans and viscous fan are causes for overheating plus the sensors that control the fans. Not starting could be caused by the overheating but most likely its a fuel or ignition issue.
1helpful
How often is best for changing c class 180 mercedes benz 1997 ENGINE OIL and GEAR OIL
I’m not sure why you would post a simple question easily answered via any shop will tell you free of charge but here’s a link to help you .
https://m.mister-auto.ie/engine-oil-mercedes-benz-c-class_lg3224_ls520/
Mercedes e230 97 gear knocking on 1st and 3rd gear
sounds like an internal gearbox issue so other than changing the transmission oil there is little else i could advise so it will need to be inspected by a mechanic , sorry no easy fix that i can think of
1997 mercedes wont go in drive until i have driven in 3rd gear
BUMMER DEAL! It could have a sludge problem that needs that lower gear nudge to get it to shift. Just changing fluid is not enough. You need stronger medicine. Try this Mega Power product as it seems made to end that problem. Hope this helps.
1helpful
My car moves forward but when i shifted to backward, car doesn't move. I checked oil level, it's very less. Is replenishing the oil will solve the problem? Are there any reasons other than oil level?
Warm the car engine.Change through all the gears and finish in N.Check the transmission oil level.If it needs trans oil,add the oil into the tube that the trans fluid dipstick is located.The gears wont work if the trans oil level is low.Probably a good idea to find the oil leak.I hope this helps
3helpful
2answers
MERCEDES NOT CHANGING GEARS
it should be in 2nd gear your gearbox is in limp mode need to have it looked at a.s.a.p ( the oil level may low)
1987 mercedes 190e replaced spark plugs put new gas and filter and battery and oil change car start but wont turn over
hello,be sure your starter motor is working,fly wheel gear(for starter bendix drive)should also check,valve clearance also,try to rotate your engine with socket 27mm,(manually) maybe your piston is stuck-up,ty
Mercedes auto gear box problem
hi,oil lever should correct,oil quality should check,filter is clean,adjust all the pressure with authorized tech.if not trans. need to overhaul, ty
E200k wont change up or down and tiptronic not working.
Hello my e300td had same problem took it to mercedes garage rev sensor had gone wrong they changed this&its okay now hope it helps derek
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
