Take 15 seconds every load to wipedown all sides/parts of rubber door boot. use only powdered detergent. do not use fabric softener. Use plain old white vinegar in place of softener. Liquid detergent and fabric softener both leave residues that can mildew. Vinegar helps stop mildew and helps rinse soap out of your clothes to keep them cleaner.
This is a very common problem with front loading washers. Take a look at this video to fix:
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
SOURCE: LG washing machine has AWFUL mildew smell
What is a P trap & why then didn't my old top-loader make my clothes smell? I think we've all been had.
Don't know if this is the same as your problem, but I had a Kenmore washer, (made by Whirlpool) that did the same thing. It was a high efficiency model without an agitator. I finally found out that this type of washer never drains completely but always has some water left in it. This water is somewhere internal that cannot be seen unless the machine is taken apart. That water goes bad and stinks. Everything smelled like mildew and for some while my husband thought I was was washing clothes and leaving them in until they dried. I ended up having to just buy a new machine and when the stinky washer was taken away, just tilting it caused all this foul water to come out everywhere. Also I found this on the internet http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
scroll down and see how other people feel about this machine. I decided that instead of buying the newest, latest, greatest, with all the bells and whistles appliances, from now on I will buy the time tested, plain jane models.
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
