Yes, same issue happened with me. Once I was playing poker game online but I stuck in between and can't able to play that game because of some technical issue.
After that I never play any games by downloading it on my system. Usually, I prefer to play poker game online because there is no chances of these kind of issue. You can also try playing game online.
If you are interested to play pemenang promo kingpoker99 then just have a look at http://kingpoker99.site/news.php?id=2756 Here you will get some easy tips to play this game over gambling website.
HI Denise.
Sometimes a Wii or Wii U is unable to read a disk, or the game will freeze or crash. And sometimes the console won't play any disk at all. Before you throw the disk in the trash or the console out the window, here are a couple of things that might get you back to playing games.13 Jul 2017
What to Do if Your Wii Is Unable to Read a Disc - Lifewire
https://www.lifewire.com/what-can-i-do-if-my-wii-cant-read-a-disk-2498308
or you could try this link.
wii won play games Google Search
SOURCE: Loading Games
I used to have the same problem and Nintendo said it was beause the optical lasers were not lined up straight. Send it to Nintendo and you will get it back in 3-5 days.
SOURCE: Gamecube game stuck in wii
Well i have expirienced the same thing. what you have to do is put the console face down so that the game slot is facing the floor then press the eject button but if that doesnt work you have to heat up the system by leaving it on for about 3 hours then tilt it and press the button and that should get the disc out for you.
SOURCE: I put my wii powersaves card into sd slot but they wont load
To use a wii powersave, you need to follow these easy steps.
1 Go on to the Wii oprion menue.
2 Go into the data management section.
3 Click save data
4 Click on Wii.
5 Click on SD card.
6 Search for your game title.
7 Click on it.
8 Copy the game data to your Wii.
Hope it helped!
SOURCE: wii wont read discs
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
160
