Question about Sansui Televison & Video
Service mode for sansui ledtv model-ledtvs jj32hk-zma
The picture is looking gost imaje i want to change it bits
6ya staff
SOURCE:
chad harvey
  • 119 Answers
SOURCE: 3 month old lg lcd/ledtv
Probably in the power supply. Take it back or call for warranty service.
Posted on Feb 25, 2011
Tony
SOURCE: My Coby LEDTV 1926 blinks red, green, blue, white,
Sorry I can't help, but mine does the same thing sometimes. It'll work fine for awhile, then no picture, but goes crazy and flashes one color at a time across the whole display, very brightly. I have it connected to RCA inputs, so I don't know if it would happen using the antenna input, but based on your experience, I suspect it would. I never got around to calling tech support, and my return period ends in two days, so it's going back to the store tomorrow.
Posted on Nov 26, 2011
tyson fields
  • 28 Answers
SOURCE: Connect a cable line (no box) to my 55 Samsung
are you saying you have no coaxial connection on the back of your tv? If thats the case, you would have to run the coaxial(cable) to a digital box and use an HDMI, or Component cable from the digital box to the tv.
Posted on May 08, 2012
gopakumarg43
  • 76204 Answers
SOURCE: I have a Sinotec LEDtv 32" it switches itself off
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Sep 08, 2014
gopakumarg43
  • 76204 Answers
SOURCE: What is the 3 digit code for coby ledtv 1526 using chunghop rm-136e universal remote control
029,025,021.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the sites by brand name to your TV
Posted on Sep 15, 2014
I have a Sharp 60 inch ledtv (LC60LE835U). The power button flashes short/long. I used the reset code but have no picture or sound. I looked through the back panel and don't see any lights. I also used the...
You lost your backlights, common issue on this set..you will need to get into the panel and replace the strips that are bad or take it in for service
Mar 22, 2018 | Sharp Televison & Video
Insignia Ruku tv 32"ledtv 720P
Please contact ROKU customer support at number below.
Roku, Inc./Customer service. 1 (888) 600-7658
Nov 25, 2016 | Computers & Internet
My Vizio e500i-b1 LEDtv went out last night. How can i tell if it's the main board or the tcon board that isn't functioning?
I would verify the voltages on the power supply board first because an improper voltage to a circuit board may make that board look bad.
Jun 18, 2015 | Vizio E500i-B1 50-Inch 1080p Smart LED...
029,025,021.
Sep 15, 2014 | Coby LEDTV1526 TV
What is the rca remote code for a sceptre ledtv?
0075.0039.0010.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 04, 2014 | RCA Universal Remote Control
I need to know how to use remote control ledtv 076eott011 on sansui tv model sled1953w
If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 13, 2013 | Radio Shack 15-2146 Remote Control
Sansui ledtv
there are 3 possible problems
the backlight could have failed
the powersupply for the backlight could have failed
or the backlight inverter has failed.
i would suggest taking it to a technician to find the exact source.
you can also take it apart and use a volt meter to test the voltage on the back light's power supply to see if that's the problem. but this kindof probrem is usually caused by the backlight burning out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tyler_d7f5052aae55714c
Aug 18, 2013 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
