SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
SOURCE: Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
SOURCE: Kenmoore upright freezer cold but not freezing
Hi!
Thanks for using FixYa. First of all please check that there is air flow in the upper vent baffle in the fridge section which is located behind the crispers. If there is no air flow at the vent baffle in the upper fridge section then this is the cause of the issue you’re facing with. The evaporator fan pushes the air through ducting into the refrigerator from the freezer and if there is any material obstructing it then clear it.
If still the problem persists then you need to check the following things:
The defrost circuit contains defrost timer, defrost heater(s) and defrost thermostat. Defrost timer failure will not put power to the circuit. Defrost heater failure will fail to defrost when the timer applies power. Defrost thermostat must be closed for defrost to take place. First locate the timer, rotate the clutch head screw clockwise slowly until one distinct click is heard. Now the timer will be set in defrost mode and defrost should complete within 30 minutes or less after which the refrigeration should start cooling again. If defrost takes place and it does not go back to cooling automatically turn the screw once again until you hear the second click, unit will start. Replace the timer. If defrost does not take place in the time frame above and the unit restarts in cooling test the defrost heaters. From the heater(s) follow the wires from each end to where they plug into the circuit. Unplug them and test through the heaters with an ohm meter. You should get a reading if they are good, if no reading then you need to replace the heater(s). If you get a reading on the heater(s) then you need to replace the defrost thermostat.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
SOURCE: Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
