Coffee Makers & Espresso Machines Logo
Crandall Lee Posted on Dec 02, 2017
How do I remove then casing from Keurig K10 manufactured in 2014 water leaks from the bottom
Patrick Gorman
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Dec 02, 2017
Patrick Gorman
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
5725
Points
38
I have taken apart a Keurig and most items are not serviceable but remove the screws on the bottom and follow your water lines and see if one came lose or is leaking.
3 Related Answers
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 27, 2009
SOURCE: 2003 crf 450 leaking coolant from hole from the bottom of the case under the water pump. What does this indicate?
It means your water pump seal is seeping at this point. Eminent failureportended. Replace water pump. Seals on pumps usually fail because of bearing wear, so this is a precursor to pump shaft failure. Good luck
espressonist
espressonist
  • 1711 Answers
  • Posted on Sep 27, 2010
SOURCE: water leaks out the bottom
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler . All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Anonymous
  • Posted on Jan 20, 2011
SOURCE: My keurig is leaking water
Mine is too... did you figure out how to fix it?
Is my Keurig the one that was recalled?
Hey Rudy,
I'm not sure which particular model Keuirg you have, but i was able to find details on the Keurig models that have been recalled. The units that were recalled were the Mini Plus Brewing Systems, with model number K10. The brewers have an identification number starting with "31" printed on the bottom. They were sold online and in stores in the U.S. and Canada between 2009 and 2014.
You can purchase charcoal water filters direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
2answers
Our keurig brwing machine has been soeweding hot water and been dangerous. could you tell how it can be replaced and what phone number i should be calling.
Some of the Keurig machines were recalled for this issue They are Model number K10 (formerly identified as B31) produced prior to July 2014. c You can call toll-free at (844) 255-7886 Monday through Friday from 8:00 a.m. to 8:00 p.m. (Eastern Time) and Saturday and Sunday from 8:00 a.m. to 3:00 p.m. (Eastern Time)
I have attached a link to the site. I hope this helps.
1helpful
Is Keurig model K40 elite brewer on recall?
Contact Keurig via phone or website to confirm but the website says only the K10 right now.
How do i remove casing of keurig k10
Some of the case is held with compression fittings, which you really have to be careful not to break. A long and very thin flat head screwdriver and some patience can probably get you there.
Why does my keurig k10 leak?
It has an overfill tray to catch water when you put in more than 10 oz. When that tray becomes full it seems like the machine is leaking but the tray is just overflowing. Empty the overfill tray and try not to overfill. Learned this the hard way.
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
1helpful
My K10 mini keeps shutting itself off
It is normal for a Keurig mini to shut itself off after 90 seconds of inactivity. Reference page 17 of the manual.
https://www.greenmountaincoffee.com/~/media/B2C/Files/Keurig%20Brewer%20Manuals/B31MiniPlus_manual.ashx
How do I get a manual for a Keurig K10 mini?
You go to the Keurig website:
http://www.keurigtroubleshooting.com/keurig_user_manuals.html
2helpful
3answers
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
