Air Tools & Compressors Logo
M
Mark R Posted on Dec 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
John, Porter Cable 16 gauge brad nail gun. Model # FN250A. It's not feeding brads in to the chamber. It just fires once and the hammer stays. Please help.
John Trevino
Level 3:
  • Porter Cable Master 1,420 Answers
  • Posted on Aug 27, 2019
John Trevino
Porter Cable Master
Level 3:
Answers
1420
Questions
Helped
1012164
Points
3200
This usually occurs when the check seal is out of place or bent driver or driver is too loose /too tight in the cylinder. The check band is usually the problem. Remove the cylinder and make sure that the black rubber band is covering a series of holes about mid section of the cylinder. If the band is in place, then problem is piston driver is bent , too loose /tight in the cylinder. Good luck with the repair.
5 Related Answers
John Trevino
  • 1420 Answers
  • Posted on Nov 25, 2008
SOURCE: BNA125A Porter and Cable brad nailer
Both of these nailers have a check seal about half way down on the cylinder. This check seal causes the piston to retract if the piston ring is not too worn. The lower bumper should not be cracked and missing pieces, and the driver guide washer must be in place below the bumper. Also check that the driver is not bent causing it to get stuck. The da250b has an upper bumper of sorts and developes cracks that can only be seen by removing and inspecting, If cracked, the upper bumper must be replaced for proper function. The bn125a nailer probably has the discharge port clogged or upper valve parts worn or cracked. The headvalve should be inspected for cracks where the oring fits and the rubber seal should fit snug on the valve. There is a spring that pushes down in the headvalve that pushes from a rubber washer of sorts, check the diagram to be shure that all parts are in order. Both of these guns will not take too much pressure. Try adjusting to about 90 lbs max.
Anonymous
  • 10865 Answers
  • Posted on May 20, 2009
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
yoopertech
  • 131 Answers
  • Posted on Jun 24, 2009
SOURCE: Porter Cable 2 inch brad nailer piston does not return
Sounds like the cylinder check seal. That`s the o`ring on the outside of the cylinder sleeve. With little holes in the groove. You have to remove cylinder sleeve to get to it.
Thanks,
Jeff
michaelwitt
  • 74 Answers
  • Posted on Aug 29, 2009
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
Anonymous
  • 2176 Answers
  • Posted on Oct 10, 2009
SOURCE: looking to buy a manual for a porter cable nail
Go to Dewaltservicenet.com and type in your model number the manual is 13 pages long. If I have helped you with your request would you please rate this response accordingly. Thank you
16 g brad nailer... Brand new... Fired 100 nails then stopped. Air goes phssst at trigger assembly when fired
There is big O-ring which is fly away - required to be disassembled and fixed. Bring to repair shop
We purchased a Porter Cable Staple Gun, Model # DA250B. Unfortunetly, it does not explain how to load the staples into the gun! Could you please help us. Thank you, ...
Porter-Cable/Delta has an excellent support site, where you can find pdf manuals, part numbers, etc.
http://servicenet.deltaportercable.com/
Porter-Cable DA250B is an angled finish nailer- it drives 15 gauge brad nails, and won't work with staples. There are some smaller pneumatic tools that can drive both brads or staples, they are typically the smaller 18 gauge fasteners.
If you have the correct 15 gauge angled nails, the DA250B manual has nice pictures showing how to insert them.
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DA250B
Jul 16, 2011 • Garden
The driver doesn't return after firing. it is a porter cable brad nailer BN200
This is pretty common with brad nailers
Remove the brads from your gun - disconnect from the air supply
On the front of your gun is a latch - open it
Check the sliding surface for build up of dirt or small pieces of metal from the brads.
Once clean polish the surface with a fine steel wool or a small brass brush
Reassemble with a drop of machine oil on the sliding surface
Oil your gun as you normally would
Using a piece of soft wood dry fire the gun 10 or so times to ensure that the dents it is making in the wood are all pretty even
Reload and nail something
1helpful
Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Driver will not return to rest position,
The plunger or anvil has damage, or your return spring in the chamber is broken. This could also be caused by mechanical issue in the anvil track.
3helpful
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Nails not feeding in
The unit need cleaning and oil. Possible a wix spring.
Top Porter Cable Air Tools & Compressors Experts
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
