Modern wiring, if you have broadband, only uses two wires.
They consist of the A leg and the B leg. The A leg is connected to connexion 2; the B leg to connexion 5.
Other connexions are concerned with earth (usually for party lines) and ringing (for telephones not on an ADSL line--telephones on ADSL get their ringing current derived from the flter). These other two wires should now be disconnected as they can cause noise.
The wires are in pairs, the blue on white has a pair, which has a little white on blue; the orange on white's pair is white on orange.
It sounds as though the blue pair are the A and B leg, and should be connected to 2 and 5.
Check on another telephone socket (it should be wired exactly the same).
The Blue and Blue/white represent the first pair in a multi pair telephone cable. The second pair is orange the third is green and so forth. If this line is active, you will get a dial tone when you place a telephone instrument on this pair (or any subsequent live pair). Notice. If you are hanging on to the pair when the telephone rings - you will experience a 60 volt DC shock. It will not kill you but you may find it unpleasant.
On your Western Electric '500' telephone set, you should have three wires coming out of the original cable, a red, a green and a yellow. Normally, the red and the green will operate your phone on a 'private line' (only one customer on a private line). Try various combinations until you get a dial tone. You no doubt have a private line as there are very few party lines around these days if you are in the USA (and please do not say). Once up on a time, there were "party lines" where neighbors shared a line and they knew the call was for them based on the number of rings. The first customer got one ring, the second customer got two rings and so forth up th as many as 4 rings. When the telephone rang, you listened for the number of rings and answered only if it was your number. Picking up a call that was not your ring was frowned upon though it was not unknown for neighbors to listen in to other neighbors calls. It was like a reality show!
If your 500 has been upgraded with a RJ-11 wire, plug the wire in just as you would any modern telephone. If yours doesn't ring, remove the cover and study the interface. You will find several terminals marked L1, L2 etc. Move the wire you find on a "L" terminal to the various otgher L terminals until it rings when called. You may also have to adjust the spring on the ringer to get it to operate properly.
I hope this information helps you get your 1960 telephone to work.
Thank you for your interest in FixYa.com and enjoy your old telephone.
IT TOOK 1.5 HOURS TO SYNC UP AND CALIBRATE A NEW TONY HAWK RIDE SKATE BOARD WITH A Wii. THE ON-LINE DIRECTIONS AND TROUBLESHOOTING = SUX!. PLEASE FOLLOW THESE DIRECTIONS IF YOUR HAVING THE SAME ISSUE: 1) Remove skateboard battery's for 1 minute 2) Reinstall 4 new/fully charged AA Battery's in the Tony Hawk RIDE Skateboard. 3) Plug the Tony Hawk Wireless USB Dongle into the "upper" WII USB Port, Turn on the WII, Insert the Tony Hawk Ride game disk Keep pressing A on the WII Controller till you get to the Error Screen saying: *Unable to SYNC up the skateboard with the WII* 4) Make sure the WII and the plugged in wireless USB Dongle are laying on the floor in front of the wireless skateboard "sideways" with the wireless dongle towards the right side of the WII. 5) The directions state to 1st press the wireless USB dongle reset/Sync button, then the so called Start button on the board, which did not work 100 different times. 6) Instead (on the side of the board) all 4 of the blue LED lights were on. Now press and hold the button which is the Start/Home/blue little house/C- looking Button on the side of the board for 5 seconds. The Blue LED lights should now all be off! 7) Now press the WII Wireless USB Dongle reset/Sync button. 8) After the Dongle sync
