Question about Whirlpool Washing Machines
Error code e05
My whirlpool duet front load washer is displaying codes e02 and f05. What does this mean?
  • Whirlpool Master
  • 2,519 Answers
Heater or heat sensor problem that has to be tested with a multimeter.
Posted on Dec 05, 2017
6ya staff
SOURCE:
duby1990
Justin Duby
  • 370 Answers
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Posted on Nov 19, 2008
Anonymous
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
Michael Childers
  • 240 Answers
SOURCE: Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Posted on May 02, 2009
Prakash R
  • 1382 Answers
SOURCE: WHAT DOES F 20 MEAN?
Hi, The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is: If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Posted on Apr 12, 2010
What is f03 and e02 error codes on duet dryer[not washer]?
Error codes are pretty generic between the washers and dryers. This appears to be a temperature sensor issue.
whirlpool duet dryer f03 and e02 error code Google Search
Same error on a washer
How to repair whirlpool duet error F3 E2
Aug 20, 2018 | Washing Machines
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have 2 error codes on my front loading Whirlpool washer...F08 and E02...What do they mean?
well I'll just say it's the kaputnick gate valve located at the whirlpool headquarters since no-one else seems to have the same explanation for a single error code
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting error code d5 on my duet sport. How do I fix this?
No d5 there is F05 Du> and DL The F05 is water not being heated . The D is for door switch not locking or unlocking .Must have complete model from washer to be sure
Oct 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F05 error for Whirlpool GHW9100L Front Load Washer
The following link explains the "F05" error code:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
I hope you find this information helpful. I have seen this error code generated by something as simple as a loose connector on the NTC sensor. Hopefully, you can resolve this with no expense. If you do require any parts, however, you can locate parts with illustrations at searspartsdirect.com or repairclinic.com. If you require further assistance, please let me know.
Sep 10, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
1,875 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
