SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
SOURCE: How To Replace Kyocera Taskalfa 180 Copier Drum
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Testimonial: "operation guide will not show the way of replacing drum..."
SOURCE: I have a kyocera taskalfa 180 and its displaying shake tonner
You can download the full manual from this site, but this page provides your answer to fix the problem: http://www.manualslib.com/manual/485194/Kyocera-Taskalfa-180.html?page=129
The toner has probably settled in one or more cartridges. Just give them a gentle shake and re-install.
