Question about Science & Laboratory
PLUMBING QUESTION/PROBLEM....the main sewer trap in a rental bldg. keeps clogging up with some soft like CRISCO white goop. Both tenants deny putting anything strange down the sink or toilet
Whatever it is, it sticks to the walls of the trap and builds up until I get a backup. I can easily remove it by hand. At first I thought it was cooking grease, but I put some in a tin can and heated it on the stove - it does not melt. I would appreciate: 1 any ideas as to what this could be, and 2 does anyone know of any lab that could analyze this for me? thanks Frank
  • 2 more comments
  • FXProglJr Dec 06, 2017
    thanks much for the input.....I'm in NYC (City water which isn't hard)and have 3 houses all on the same street (for 40 yrs already). This is the on;y house that has ever had anything like this block the trap....
  • ray gallant Dec 07, 2017
    also kinda agree with Clive it might be laundry detergent many over use powdered type and it might not be dissolving as it should. ask tenants to use liquid only . see if problem goes away
  • FXProglJr Dec 12, 2017
    thanks for the thought Ray, but got to cross this one off - washing machines are not allowed in the building
  • Dianne Barrett
    Dianne Barrett Jan 22, 2019
    Many people take vitamins and the excess is peed out causing a white ppt. which lines many sewer systems in our countries. 2ndly, the toilet paper from Costco has plugged many sewer systems when the lines are not large enough to handle the mash. The high rise apt. bldg. I was in refused to allow high/low flush toilets for this reason and asked people not to buy toilet paper from Costco.
  • 882 Answers
Plumbing problem - White Goop:
If your water is too hard, soap may not be dissolving completely, so creating a 'cloud' of macroscopic particles.
Posted on Dec 06, 2017
    Top Expert:
  • 66,470 Answers
Check with your local sewage treatment plant .
Posted on Dec 05, 2017
Testimonial: "thanks much....hadn't thought of that....I'll ask NYCDEP"
Anonymous
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: My 3 1/2 yr old GE profile spacemaker microwave stopped heating.
Some components can be replaced from the front, but not the high voltage parts including the magnetron.
You can download GE owner's manuals and installation instructions here. They make it easier to remove from the wall.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
GE Customer Service is here if you want to request a magnetron.
Posted on Dec 17, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 10, 2009
Stephen Lam
  • 670 Answers
SOURCE: Microwave will not cook
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Posted on Dec 24, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: I have a GE Spacemaker XL1800 over stove does not cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Apr 20, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my microwave turns on when
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 22, 2010
Plumbing question. I just had a main serer trap clog up for the 2nd time in 6 months. It was clogged with some soft, white goop like lumpy CRISCO or gelatin. I cleared it easily by hand.
My first thought was coconut oil/butter. Many millennials and younger are slathering on coconut butter after shower clogging plumbing in the US, but i should melt. When oils combine with soap they can produce a tough log that does not easily respond to lye type drain cleaners. Ask the tenants if they use coconut butter in the bath. Oils and fats can also combine with calcium in hard water to form a nasty, hard to dissolve "soap". Any chance they are pouring fats/oils/bacon grease down the grinder or dains? Als see https://usatoday30.usatoday.com/money/industries/environment/2011-04-27-clogged-sewers_n.htm
Sep 23, 2017 | Plumbing
The tub is clogged with hair
Few plumbing issues such as Dripping faucets. Running toilets. Leaky valves. Clogged bathtubs can be solved by our own trying few things.
1)Firstly lookout for what is causing blockage such as soap or hair inside the pipeline blocking water just pull it out from pipes.
2)Secondly use a plunger(Tool used by plumber to clear clog) pour some water in bathtub to cover the plunger block the overflow of water with rag.Place the plunger over drain pull up & down 5 to 6 times.
3)Lastly if still the clog is not cleared try out with snake a long flexible steel cable wound on a handle In a sink you just feed the snake down the drain, but on a bathtub you need to feed the snake down through the overflow plate opening. Start by feeding about 3 feet of the snake into the opening, turning it as you push it forward. You will feel some resistance as you work the snake through the trap under the drain, and the turning helps to move the head through the trap. The snake should either break up the clog by pushing its way through it, or your turning will hook the end of the snake onto the clog and you can pull it out.
After trying with above if still there is plumbing issue call sewer line repair services for help.
Grease Trap Services
May 03, 2015 | Maax Home
Sewer smell in house from septic tank and idle system
If the house has been sitting for a long time, the traps may have dried out and are not stopping the sewer gasses from being trapped back, flush all toilets and run some water in all the sinks and tubs, to refill the p-traps, also don't forget to pour some water down the washer drain pipe. HOPE THIS HELPS...
Nov 10, 2014 | Plumbing
Is it legal to install a plumbing p trap behind a dishwasher in an exposed wall?
What are you doing? P traps stop sewer gas from coming into the house --only if there is water in them. If you are talking about putting your drain line into the P trap line, you could. You need to have a plumber see your installation to be sure.
Mar 04, 2014 | Dishwashers
Sewer smell coming from sink when water runs into drain
is there a trap in the sink drain just under the sink
if not put one in
a trap holds water in a bend so sewer gases dont come up through the drain
Nov 20, 2013 | Dishwashers
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kitchenaid superba disposal
IF THE WATER IS NOT IN THE BASIN OF THE DISPOSAL, THE PLUMBING IS THE PROBLEM, NOT THE DISPOSAL.
YOU CAN TRY TO TAKE THE TRAP LOOSE AND SEE IF THERE IS ANYTHING STUCK IN IT OR YOU COULD TRY SOME DRANO IN THE SINK WITH THE WATER STANDING IN IT. THE TRAP IS THE PART OF THE DRAIN THAT RAISES UPWARD TO HOLD WATER. IT KEEPS THE SEWER GASSES FROM COMING UP THROUGH, BUT IT ALSO IS A GOOD CATCH ALL FOR HEAVY ITEMS AND GREASE.
LOOSEN THE NUT LOCATED AT EACH END OF THE TRAP. HAVE A BUCKET UNDER IT TO CATCH ANY WATER THAT DRAINS OUT. REMOVE THE TRAP AND SEE IF THERE IS AN OBSTRUCTION IN IT.PRESSURIZED AIR WILL SOMETIMES CLEAR AN OBSTRUCTION IN A DRAIN LINE ALSO,
Jan 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Science & Laboratory Logo
472 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
