Question about Toshiba Tablets & eReaders
Toshiba 55L421U is not shutting down and is blinking power button after trying to add chrome cast to my tablet .any suggestions ?
gregp507
Greg P
  • 538 Answers
SOURCE: I have a google chrome cast and i want to use my fire tablet as remote to cast but it says my devise is not compatible with google play services
Because it's not.
Posted on May 24, 2017
How do I factory reset a Ematic EGQ327M tablet without a password
FixYa
Ematic Eb104 eBook Reader
Question about Ematic Eb104 eBook Reader
ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
by sharhonda cox on Jan 8, 2014
Add Comment · Flag · Share
April Argo
Level 1 New Friend · Contributor
Andrew Jones answer was correct...
Helpful 0 Not Helpful ·Add Comment ·Flag
M Asish
Level 2 MVP · Expert
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Aug 04, 2018 | Tablets & eReaders
Would like to cast my music from my tablet to my tv
chrome cast or mirror apps from google play store
to learn more check out you tube videos
just type in what you asked above cast music from my tablet to my tv
Mar 28, 2018 | Tablets & eReaders
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
Dec 24, 2017 | Toshiba Tablets & eReaders
My chrome tablet has a blue dot wont turn on or shut off whats wrong
Shut it down by simultaneously:
Holding down power button
Holding down volume down
Holding down Home button
For 10 seconds.
After shut down, restart it.
Aug 31, 2017 | Tablets & eReaders
My Samsung galaxy 2 tablet keeps restarting itself while i'm in the middle of something . why ? how can I fix this problem ?
Once the tablet has shut down, press and hold the Volume Up and Power buttons simultaneously until the Samsung logo appears. The Samsung Galaxy Tab will boot into ASR (Android System Recovery) mode. 3. Use the Volume rocker to highlight the 'wipe cache partition' option and the Power button to select it.15 Sep 2015
How to Fix the Samsung Galaxy Tab Reboot Loop - Appuals.com
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Samsung+galaxy+2+tablet+keeps+restarting
see if this helps you out.
Dec 17, 2016 | Samsung Tablets & eReaders
Won't power on.
Shut down the tablet. Then press and hold power button and volume up button until the boot menu is loaded. Then select HDD recovery. Now tap Yes, select troubleshoot, select Reset your PC and follow the instruction on the screen to finish the procedure
Jun 24, 2015 | Toshiba Encore 2 Wt8-B264 Net-Tablet Pc...
How can i fix my toshiba excite 10 tablet doesnt want to connect to my wi-fi it doesnt let me add a network or scan either please help me
The solution is a factory reset....I know you have done this but did you follow these instructions?
1.Make sure the tablet is off and not in standby.
2.Hold down the 'Volume Up' and 'Power' buttons simultaneously until the two Android icons appear.
3.Use the volume buttons to select the white box on the right.
4.Once selected, press the power button.
5.Use the volume buttons to select 'wipe cache partition' and then press the power button.
6.Select 'Yes' and press the power button.
7.Use the volume buttons to select 'wipe data/factory reset' and then press the power button.
8.Select 'Yes' and press the power button.
9.The tablet will now reset.
Feb 04, 2015 | Toshiba Tablets & eReaders
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Apr 17, 2014 | Tablets & eReaders
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Tablets & eReaders Logo
87 people viewed this question
Top Toshiba Tablets & eReaders Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
