Hi John.
Troubleshooting an Ice Maker That Leaks
When troubleshooting ice maker there are a lot of different things to be aware of. Ice makers are very useful when working correctly, however if there are any problems, it's important to fix these as quickly as possible. One common problem with ice makers is that they can leak. A leaking ice maker can be a result of a number of different reasons.
You will need to put your detective's cap on in order to inspect and diagnose what is actually causing the problem with your ice maker.
Checking Your Refrigerator
For the ice maker to work properly it needs to be perfectly level. If it isn't level, this can cause leakage.
Before leveling the freezer you should unplug it so that you can work on it safely. Check that the freezer is perfectly level by placing a spirit level on top of the freezer from side to side. The leveling feet can then be adjusted by twisting them to raise and lower them. Continue this until the freezer is aligned properly from left to right.
Then repeat the process by putting your spirit level from front to back to ensure the freezer is completely level.
Ice Maker Level
The ice maker unit itself can also be leveled. This is inside the unit and can be repositioned if needed. Loosen the mounting screws and align the ice maker unit so that it is perfectly level. After leveling, ensure that the mounting screws are tightened to prevent the ice maker from moving.
Water Supply Line
The water supply line could also be damaged or broken. This is the tube that is behind your freezer. It's a fairly strong tube and is susceptible to damage. Check that the pipe isn't pinched or kinked.
Fill Cup
When water enters your freezer it will be put into the fill cup. This is a funnel that directs the water into the ice cube molds. If this isn't aligned correctly, it can cause problems with leaks.
If you see any ice forming on the fill cup, this could be because the valve is not working properly.
Inlet Switch
Remove the inlet switch and inspect it for signs of corrosion or damage. If any of the terminals have corroded, you will need to replace them. Using a multimeter, you can check that the switch is working properly. Press the switch and check that it connects and reduces the resistance as it should.
Inlet Valve
If you are testing the inlet valve, you must first disconnect the power so it's safe to work on your freezer. The inlet valve is located in the bottom of the freezer. Turn the water off at the source and then disconnect the supply line. Use a bucket to catch all of the water from inside the inlet valve.
Label the location of all the wires and disconnect them. You will also need to remove the inlet supply tubes. Using a multimeter, check the resistance of the coil. Also inspect the mechanical functioning of the inlet valve, as it can fail mechanically as well as electronically.
After following this troubleshooting guide for your ice maker that leaks will get you back in business. Now you can enjoy a cold beverage for your hard work!
Comments
Troubleshooting an Ice Maker: Ice Tastes Bad
Shares
When troubleshooting ice makers there are a number of steps that you can take to find the cause of the problem and put it right. One common problem is when the ice doesn't taste right. If the ice tastes bad, then there can be a number of reasons for this.
When working out why the ice tastes bad there are several things that you will need to consider. The problem could also be caused by one or more of the factors that could make solving it slightly move complicated.
Washing the Ice Bin
The ice bin is the container that stores the ice, if this becomes dirty or moldy it can make the ice taste nasty. Simply taking the ice bin out of the freezer and then washing it will solve the problem. Read the instruction manual to find out where the ice bin is located.
Unscrew or unclip the ice bin and then wash it in warm soapy water. Dry the ice bin and then reassemble it. Place it back into the fridge and then find out whether it has resolved the problem.
Old Food
If there is any old food in your refrigerator, it should be removed. The ice could taste funny because of this food. Empty your refrigerator of any old food and wash all of the shelves so that the fridge is completely clean.
Once the old food has been removed and the fridge has been cleaned completely you should then test the ice maker to find out whether the problems still affect you.
Flushing the Supply Line
The supply line carries water to the ice maker. Sometimes the water can become stale, which is why you might be able to cure the problem by flushing the water pipe out with fresh clean water.
Test the ice maker after flushing the supply line to ensure that the water is now clean that the ice doesn't taste bad.
Water Inlet Valve
If the water inlet valve is damaged, then this could also be because of the water inlet valve. If the water inlet valve is damaged or broken, it can leave the water exposed to smells inside your fridge, which can make the ice taste bad.
The water inlet valve will need replacing if it is damaged or broken. By replacing this water inlet valve you will be able to correct the problem and enjoy better tasting ice.
Replacing the Water Filter
There is a water filter inside of your fridges ice maker that is designed to remove particles and bad smells from the water. The water filter needs to be removed and replaced.
The water filter should be replaced with the same type and model suitable for your freezer. Use your freezers model to ensure that the correct filter is fitted.
Supply Line Filter
If your fridge doesn't already have a supply line filter, then fitting one could greatly help to reduce problems with the ice tasting bad. These can be fitted to virtually any ice maker.
Now you should be in good shape thanks to this troubleshooting guide for an ice maker that was producing bad tasting ice. It's time to reward yourself with a cold beverage.
SOURCE: water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
This happens when the teflon on the mold is peeling.(flaking) It pushes water over the side. Otherwise check the clip in the back that holds the fill tube in the water cup. If the clip is missing then the fill tube could be splashing water over the mold
