SOURCE: My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
SOURCE: Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
SOURCE: Ensoniq KT-88 - sustain pedal works opposite the way it should
Usually that indicates that the polarity of the jack for the sustain pedal has been switched or someone has substituted another pedal with the wrong polarity. Try looking in the manual to see if that is an editable parameter for people who might not be able to obtain an original pedal. You may have to initialize the keyboard which is on page viii of the manual. The jacks on the back for footswitches are on page 1 and 2. The footswitch settings are on page 9. I found the manual here:http://soundprogramming.net/manuals/Ensoniq_KT-76_KT-88_Manual.pdf I don't know if you have the single footswitch or the optional stereo footswitch. If it is the single footswitch, the default setting should work correctly if it is the original SW-2 or SW-6 pedal switches. If it is the optional SW-10, the FTswL setting should be Unused. Hope this helps.
SOURCE: Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
SOURCE: Fc4 sustain pedal is in
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
