SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
SOURCE: dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
SOURCE: dyson dc 41 roller brush will not turn
You can download a .pdf copy of the DC41 user guide directly from our website:
http://media.dyson.com/downloads/us/floorcare/manuals/DC41_OPMAN_US_181011.pdf
Please note, for information on assembling, using and maintaining your machine, you can also find help guides and videos on our website:
http://www.dyson.com/support/help.asp?product=DC41-IRSPU&article=32
