SOURCE: how can i get GPRS and MMS settings for o2 for this phone
You will need to get the settings from your service provider (people who supply your sim) and check with them that mms and gprs is enabled on your sim. Enter the settings they give you in the connection settings screen on the phone
(start -> Settings ->connections->gprs (if the phone menus are still at there default)
one set for mms and another for gprs
for gprs
select menu->add
input the settings and set "connects to" to internet
for mms
select menu->add
input the settings and set "connects to" to mms
best of luck
SOURCE: manual application to apply for port, wap, gprs, mms in blackberry 8800
Try this :
Go to your phone MENU -> CONNECTIVITY-> BSNL GPRS
or
MENU -> CONNECTIVITY-> BNSL PREPAID SERVICES ->GPRS SETTINGS.
GPRS and MMS SETTINGS will be send to your phone shortly, along with the instructions on how to install. Goodluck......a rate from you for this solution will be much appreciated. Thank you!
SOURCE: mms gprs settings
ring o2 again and ask for a sim update, and a gprs install message, this will diagnose your problem
SOURCE: I dont have the t-mo mms setting under data account
Rename one of the settings fet, etc
apn is - wap.voicestream.com
