Battery runs out fast
Many things can cause rapid battery drain. Ensure that you only have wifi enabled when you are using it, otherwise the phone will always be searching for wifi hot spots and this drains battery power. The same with bluetooth mode. If the phone is 4G capable, and it it turned on, it will search for 4G signals and use extra power. 4G uses much more power than 3G does, so if you don't need the extra speed, disable it when not needed. Lastly, if you are using your phone as a wifi hotspot for others, you are looking at definite battery drain there.
