SOURCE: LCD Display
Something is wrong with the lens unit or the ccd imager. Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
SOURCE: LCD screen is totally white and absent of color
Sounds like a loose ribbon cable -- the one that connects the screen to the circuitry inside the camera.
Try squeezing the body of the camera near the bottom 'Samsung' logo, to try to snug-up the connection. Brace the front (under the lens) with your index fingers, and press firmly with your thumbs on the back over the logo just under the screen.
You might try squeezing around the other edges of the screen for good measure in case something else came loose.
-Fionn
SOURCE: Samsung SPH-M300 display screen is white
take the battery out and place it back in the phone that usually works i work for sprint customer support not technical support but that seems to do the trick alot it resets the phone if that dont work dial *2 from ur mobile device to call technical support
SOURCE: Samsung i450 totally white screen
Hello Sir,
A total white screen is seen usually when the phone's software is corrupted by infection ( Virus, etc ). Or the other reason may be that the phone's software version is outdated and needs to be updated. You have to update the software of the phone which will reset all the info of the phone. If you have the PC Suite, try to retrieve back all stored contacts and data and then update. If you are having difficulty in updating or confused, you can freely take it to a Samsung Service center. They will do it instantly.
Thank you Sir,
Have a nice day.
Testimonial: "Thanks a lot for the suggestion. Il surely try it out"
