SOURCE: Java Applications Not Working On My Cingular Se 810i
i understand ur problem , but it has been very frequently noticed that most of the application available on net are not compatible with Sony Erricsson handsets...plz make sure that the apps u r trying to install are compatible for ur phone , it is a clear java version mismatch...
SOURCE: Java Applications Not Working On My Cingular Se w810i
Reinstall the Firmware or updating to the latest software from S.e 's site.
that must be then some hardcore java errors?
SOURCE: I cannot comment or "like" somone's comments on my FB app.
The reason behind this problem is because you were not friends thus prohibits you from liking or commenting into it. In case you were friends, it simply means that he only allowed some people to like and comment it. See Facebook Account settings or ask for assistance in FB Help Support.
SOURCE: screen keeps going white and giving me a app error 523
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
FileExplorer v3.0 alphaSymbianize Forum
[img src="http://handheld.softpedia.com/images/software/screens/FileExplorer-Java-0.jpg" border="0" alt="">
FileExplorer is a program for managing files on the phone and memory card.
Current features include hiding/unhiding of folders and files, password protected access to the program and copying and moving files.
It also features a slideshow viewer and image viewer. Will NOT open other files except jpg and png. This is NOT the final version. Its a pre-release build.
IMPORTANT Settings before running FileExplorer:
After FileExplorer has been installed you'll need to configure the Access Permissions to allow FileExplorer to access the phone local file system and the internet. How this is done depends on your phone. Please read the below section for instructions for your phone type.
Configuring Access Permissions for FileExplorer
Sony Ericsson phones:
Go to either Applications or Games (depending on where you installed FileExplorer). Highlight FileExplorer, but instead of opening it, press More->Permissions.
Select Read User Data and set the access permissions to "Ask once" or "Ask Always". Select Write User Data and set the access permissions to "Ask once" or "Ask Always".
Nokia Series 60 phones:
Go to Tools > Manager > FileExplorer > Options > Suite settings
Select Read User Data and set the access permissions to "Session" or "Ask Always".
Select Write User Data and set the access permissions to "Session" or "Ask Always".
Nokia Series 40 phones:
Go to FileExplorer->Options->Application access->Phone access
Torch Keys:
Left Softkey(Nokia): Change color
Right Softkey(Nokia): Go back
UP/DOWN arrow: Increase/decrease brightness
LEFT/RIGHT arrow: Cycle through preset colours
8 key: Toggle Circle light or Full screen light
0 key: Reset all settings
What's new in this release:
· Shows hidden files and folders with separate icons than the normal ones.
· Improved the support for Sony Ericsson phones. Should work but haven't tested though. Do send feedback
· Added support for zip files and nokia themes but it's under work and will not work.
· Changed the UI a bit adding a shortcut to jump directly to a path
· Added a torch with different colors. The flashlight doesn't work yet.
· Added Nokia Theme creator UI. Still under development.
· Support for zipping files and upzipping them. Working on them. To get torch which remains ON permanently press the UP arrow which changes the brightness level.
http://www.symbianize.com/attachment.php?attachmentid=52054&d=1216885320
