The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
SOURCE: Bowflex TC5000 Treads are hitting each other
Please watch this videos and make adjustments
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQhttp://www.youtube.com/watch?v=hKbAqvuOBS0&feature=relatedhttp://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Qhttp://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=relatedhttp://www.youtube.com/watch?v=CuMjcPLYehw&feature=relatedhttp://www.youtube.com/watch?v=yX_0vRPdMfU&feature=relatedhttp://www.youtube.com/watch?v=zXeHMWTcLUY&feature=relatedhttp://www.youtube.com/watch?v=dxpOOPetVLo
SOURCE: Treads are hitting each other Bowflex TC5000
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQhttp://www.youtube.com/watch?v=hKbAqvuOBS0&feature=relatedhttp://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Qhttp://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=relatedhttp://www.youtube.com/watch?v=CuMjcPLYehw&feature=relatedhttp://www.youtube.com/watch?v=yX_0vRPdMfU&feature=relatedhttp://www.youtube.com/watch?v=zXeHMWTcLUY&feature=relatedhttp://www.youtube.com/watch?v=dxpOOPetVLopLEASE DO THESE ADJUSTMENTS AND FOLLOW THE STEPS.
sincerely.
I have a brand new motherboard for sale that might remedy your issue.
