Here are the instructions for removing the battery and replacing it from your friends at Headsets.com!
1) Remove the headband or earloop.
2) Pry the battery door away from the shiny, black plastic strip on the tip of the headset using your fingernail.
3) Carefully flip back the speaker cover to expose the battery.
4) Gently remove the battery connector from the headset by pinching all three wires (red, black, and white) between
two fingers and pulling outward away from the headset.
5) Connect the new battery to the headset and gently close the battery door.
6) Place the headset into the charging base with the microphone tip pointing UP.
If you're having difficulty give our Product Support team a call at 1-800-923-0018 and they can walk you through it over the phone.
- Mason
[email protected]
