The LAN ports on my Linksys wrt54gx-SRX 200 wireless router only send/receive @ 10mps not 100.
1. Click Start => Settings => Network Connections
2. Right click on your LAN connection and click properties
3. Under General Tab, click the configure button to configure your Ethernet adapter
4. In the dialog box that appears, click the Advance Tab
5. Under Property, scroll down to SPEED and Duplex and set the property to 100Full
However, you can set it to its default value: Autonegotiation. It you have switch or hub that runs on 10mbps, it should run at 10 and not 100mbps
Its like someone have entered the http server on the router. login on to router and search for lan speeds or reset the router to default.
