E5 unbalance load either put more item in are take some out unplug washer for 5 min should reset the code
Testimonial: "Dear Wooten, The error came when it was running, now its empty and i checked all point, it starts, pump drains water, then it took fresh water, but i noticed the drum is not moving like before it moves slow to check the cloth weight etc. as it takes fresh water then sudden sound came with Error 5. so please help in this regards."
dear faisal shoukat if drum not turning you could be basket bearing need replaceing if you hear a noise are belt need replacing if you not sure how to check these item might be best to call a appliance service ok thank you
Aoa.i would ask that kenwood kwm 7020 faf washing machi parts available?
SOURCE: Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Print unable error message
Try this link for your solution...is related to 3A...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000055/faq002555_001.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=11
SOURCE: neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
SOURCE: Hi, I'm looking for a
Hi.
Unfortunately Gala does not make any documentation available for online download.
The GL95LA should be the 5Kg 800 Rpm model.
To get the manual click and open Gala page here, then scroll down Gala page and fill the form titled"Contact us about 5Kg Gala Washing Machine 800rpm" .
In the form write model number and part number of the washer, as printed on servvice tab and ask to send you a manual for your appliance, possibly in PDF format.
Regards.
Ginko.
