Question about LG Televison & Video
How do I fix my LG 42PG25 plasma TV? The model number is 42PG60UA. What should I try next see details below?
I have a LG 42PG25 plasma TV manufactured in May 2008. The model number is 42PG60UA. It has a LGE PSU EAY39333001 PSPU-J704A Rev 1.0 power supply unit. It has a EAX42297601 Rev J YSUS board, a EAX41603501 Rev J ZSUS board and a EAX41833301 Rev C CTRL control board. A few weeks ago, the TV would power up but with a blank screen. The solid red standby light in front works. When I press the front power button, I hear a solid clunk sound and the standby light changes colour from red to blue and starts flashing blue. At about the 5th blue flash approximately 5 seconds in I hear a buzzing sound in the back. At about 18-19 flashes later the light stays solid blue with no screen or sound. When I turn the power button off, it takes about 11-12 second before the solid red light turns off complete with a clunk sound. I watched a lot of LG TV repair videos that led me to believe my PSU was damaged. I ripped apart the back panel and found Capacitor C235 blown from the PSU board. I replaced it and nothing changed. I had spare 10V 3300uf capacitors and replaced C232, C233 and C234 as well and nothing changed. I checked fuse F101 and F801 on the PSU and both were good. I checked fuse FL201 on the YSUS and it was good. I checked the some voltages on the P811/P64 testing terminal right beside where the power goes from the PSU to the YSUS - all voltages were in spec for all the testing terminals VS, VS, NC, GND, GND, VA, VA, GND, M5V, M5V. I tried isolating the buzzing sound from the YSUS and it is sounds like it is coming from a 4 pack of glued together red capacitors C701, C702, C919 and C920 on the YSUS board, or possibly the two copper coil things I think called L901 and L701. I am not sure if it matters, but when I turn on the TV, control board light D103 is this a diagnostics light? comes on but then immediately goes to D104. Light D104 stays lit up until about 60 seconds when I hear a change in the buzzing frequency a bit lower and then D103 comes back on and stays lit. I also see a light on the video board it has a sticker that stays 42PG60UA, light LD803 that stays lit up the whole time with TV tries to power on. What should I try next?
    Top Expert:
  • LG Master
  • 30,331 Answers
It is 19 years old, and I would say beyond economical repair. You will be chasing blown components that were damaged when the power surge or brownout occurred. It is only a 42" set and it is plasma. Technology has moved on to 4K Ultra HD, LED and smart hubs. Treat yourself, it's Christmas :>)
Posted on Dec 19, 2017
6ya staff
SOURCE:
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: 55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
Posted on May 16, 2008
vinhson65
  • 257 Answers
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Posted on Aug 13, 2009
Paul
  • 381 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
eagle338
eagle338
  • 4889 Answers
SOURCE: My TV Picture is blank
Can you please tell me the make and model of the tv so that we can commence the diagnosis?
Posted on Dec 28, 2010
Pspu-j702a power supply
Can't help with a service manual, but in case a repair service will do here's a link for repair service for PSPU-J702A:
http://www.coppelltvrepair.com/p/490/eay39190301-psu-j702a-lg-power-supply-board-repair-service-for-dead-or-clicking-on-and-off-tv
Hope this helps!
Feb 27, 2013 | Televison & Video
LG 42PC3RV-ZJ PSU part numbers
Go to Shopjimmy.com and type in your Model Number.
Oct 08, 2012 | LG Televison & Video
Tv wont turn on, geen light flickjers but goes back to red and does ot turn on, i unplugged tv while it was on by accident.
The main board and or power supply is seeing a problem is shutting down the TV.
The cause for your issue could be the power supply, main board, and or the drive board(s) that drive the plasma screen. Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics.
Perhaps the following can help you with a warranty repair.
1. If your TV was purchased from January 1 2008 to today---The TV does have a 1 year warranty on parts/ labor and a 2 year warranty on just the plasma screen.
2. If your TV was purchased before January 1 2008---The TV does have a 2 year warranty on parts/ labor and a 2 year warranty on just the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 60PC1D 60 in. Plasma Television
Need owner's manual for LG 42
You can get the manual on link below. Go to support then look under documents on right side to download manual.
http://www.lge.com/us/tv-audio-video/televisions/LG-plasma-tv-42PQ30.jsp
Nov 25, 2009 | LG 42PQ30 42 in. Plasma TV
Is there such a thing as circut board power pack for a Plasma tv 50P3CD?
There is such thing as power supply unit for LG 50PC3D Plasma TV with panel model PDP50X30010.Part number is 68709M0046A. LG part number is 6709900020A.
Nov 03, 2009 | LG 50PX5D 50 in. Plasma HDTV
NEED A BASE FOR PLASMA TV
Manufacturer LGE Part Number 3501900014B Description BOARD ASSEMBLY
Aug 20, 2009 | LG 42PX5D 42 in. Plasma HDTV
After loud cracking noise no picture on plasma
The most likely the TV has a power supply related problem. A power surge can cause the problem. Last thing you want ot do is void the warranty by opening up the TV. Here's info to get your warranty started:
http://www.lge.com/us/support/repair/support-warranty-claims.jsp
Jun 28, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
No signal on tv
i have 32ins Samsung displaying no satellite signal what is solution?
Aug 15, 2008 | LG Televison & Video
Televison & Video Logo
265 people viewed this question
Ekse
RONALD CARTER JR
