The first thing to do when you see the NF or 4E error code appear on your Samsung washer:
Step 1 - Remove the unit from power! Be sure the water supply valves on the wall behind your washer are fully open. These 2 water valves must be ALL THE WAY open to provide water to your Samsung washer. Turn them all the way counter-clockwise to be sure. If you have check valves on the wall, make sure they are turned all the way open and parallel with the water supply hoses. If both the water supply valves are fully open, proceed to step 2.
Step 2 - Check to be sure the water supply hoses are not bent, crimped, or kinked. If the hoses are bent, this can prevent water from getting to your washer. Be sure that when you last pushed the washing machine back towards the wall, you did not inadvertently get the water hoses crimped behind the washer, as this happens often. To be sure, get a mirror and a flashlight and look behind your washer without pulling the washer away from the wall. If the water supply hoses are bent or crimped, slide the washer out enough to get your hand down there to get the water supply hoses straight so the water can flow properly. If the water supply hoses are too short, replace them with longer water supply hoses so the water lines do not get bent when you slide it back into place. If the water supply hoses are not crimped or bent, proceed to step 3.
Step 3 - Be sure there is nothing clogged inside the water supply hoses. To check this you need to turn off the water valves that supply water to the washer. Unplug the washing machine from power or turn off the breaker. Slide the washer out far enough to get to the water supply hoses that attach to the back of the washer. Remove the water supply hoses from the back of the washer. (Keep the water supply hoses attached to the water valves on the wall) Be careful as there may be water mesh filters installed in between the water supply hoses and the water inlet valve. If so put these aside and clean if needed. Get a bucket and be sure the water supply hoses are not clogged by slowly opening the water valve one at a time and let the water flow into the bucket. If the water flows freely then the water supply hoses are not clogged. This is to test to be sure the water is flowing properly from the water hoses and valves. If the water does flow as it should from the water supply lines proceed to step 4.
Step 4 - Check where the water hoses were attached to the washer. You will need to pull the washer all the way out so you can get behind it. The part that the water supply hoses screw into on your Samsung washer is the Water Inlet Valve or Valves. Check the water inlet valve to be sure there is nothing clogging or blocking the water from entering. There may be small water mesh filter screens on the water inlet valve that could be clogged, clean if needed. If you do not see anything clogging the water inlet valve or valves, proceed to step 5.
Step 5 - The water inlet valve itself may be clogged internally, have a loose electrical wiring connection, or the solenoids in the water inlet valve are not operational. If you suspect the water inlet valve is faulty or has a loose connection, you will need to open the washer up to gain access to the valve. Remove power first. Check to be sure that the wiring harness is connected to the water inlet valves. Be sure it is secure and not loose. If the wire connection is attached to the water inlet valve, you may have a bad or faulty solenoid in the water valve or valves. At this point you could test them with a multimeter or simply replace it or both.
NOTE: SOME Samsung washing machines have 2 water inlet valves, 1 for COLD water and 1 for HOT water. Other Samsung washers have a hot and cold water inlet valve as one part.
SOURCE: washing machine
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
[email protected]
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
SOURCE: samsung washing machine ji453s
yes i did solve the problem, the water pipe leading to the sensor had a very small hole next to the clip which i disconected cut and replaced, problem solved.
SOURCE: Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
