SOURCE: tv sound & surround sound
do you have audio hooked up to your surround system from your tv ? if not you need this this to get both. from the PS3 to the TV and from the TV to the surround system. if you have HDMI on your surround system plug it in that way instead . PS3 to surround system then TV to to surround system .
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
SOURCE: No sound from TV only when playing DVD
when the tv is hooked up to the suround system u dont want sound to come from the tv cause you will hear a echo it best to let the sound come from ur home theater
SOURCE: no sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
SOURCE: the surround sound only plays on dvd not tv
most tv shows will only be broadcast in 2.0 not 5.1 or higher. if you have a converter box, that may also be the problem.
